C23op
May 26, 2017Follower
Netgear 6300v2
Currently, I have a Netgear 6300v2 setup with 3 WD Mycloud devices. When trying to transfer files from one cloud device to another via wifi. The transfer speed varies from 4mb/s to 0mb/s. This is very frustrating and I would like to know is there a solution to speed up my transfers.
Thanks
- DexterJBNETGEAR Moderator
Hi C23op,
1. What is the firmware version of the router?
2. What is the transfer rate between the My Cloud devices and the computer?
3. Have you tried using another computer?
4. Have you tried resetting the router?
5. Have you tried re-flashing the router?
Dexter
Community Team
