Caliwbj
Apr 12, 2024Follower
Netgear app doesn’t match other WiFi speed test
So I upgraded my internet speed to 1gig. When I run my WiFi speed test on my Netgear app it doesn’t show more then 400 + mbps but when I run another WiFi speed test they are 900+. Why? I’ve done every...
the problem with the netgear app is you can't choose which server the speedtest runs off. It could be running off one that doesn't max out the connection. It used to be more prevalent.
As long as your other apps are showing full speed, I wouldn't worry about it.
