Freebird317
Jun 01, 2020Luminary
Netgear App for IOS is no longer showing what devices is connect to which SSID
Netgear App for IOS is no longer showing what device is connect to which SSID. All i see are devcies connected "wired" and "wireless", I do not see "wired", "2.4Ghz", "5Ghz" like i use to.
Freebird317
Jun 09, 2020Luminary
Christian_R wrote:Hi Freebird317,
May you try reinstalling the Nighthawk app.
Christian
I have tired that, does not work
the app is acting very strange. Most of the time when I look at devcies it will say wired and wireless. Everyone once in awhile I will see 2.4, 5, wired
Christian_R
Jun 12, 2020NETGEAR Employee Retired
Freebird317 - May you provide us with the model number of your router and the current firmware version its on.
Thanks,
Christian
- Freebird317Jun 12, 2020Luminary
Model is RAX120 and firmware ver is 1.0.1.122
- Christian_RJun 15, 2020NETGEAR Employee Retired
Freebird317 - Please revert to the previous firmware version and let us know the outcome.
Christian
- Freebird317Jun 22, 2020Luminary
I have downgraded my firmware all it appears to be working correclty now. Is there a beta ver I can try that is newer then 1.0.1.122?
