rcb2022
Oct 11, 2022Aspirant
Netgear app is crap
I just want to reconnect a scanner to my network. I've spent about two hours chasing Netgear's helpfully circular links to try to reset my admin password- the biometric marker apparently just record...
rcb2022
Oct 12, 2022Aspirant
Got in, finally.
Gateway is 24.24.174.96, firmware is v1.0.4.84.
rcb2022
So, I just went to RTFM, and it looks like there is an LED on the top of the router that is a WPS button. Huh. It would have been great if any of the Nighthawk support docs I looked at mentioned that it has a WPS button....
Going to go see if this works...
- plemansOct 12, 2022Guru - Experienced User
Let me know if the wps option doesn't work. The manual does go over how to get the wps pin number.
How do I specify WPS settings on my Nighthawk router? | Answer | NETGEAR Support
