TIEfitrRAXE500
Oct 27, 2023Aspirant
Netgear app says my Gateway offline
My Netgear App where it lists the devices always shows my Fiber Optic Gateway Modem (Humax BGW320-500 through AT&T) as OFFLINE. The modem is set up with pass thru so the router can do i's thing. The...
- Oct 27, 2023Thank you for your response to my question. My Humax gateway that brings the Fiber Optic into the house is currently set on pass thru mode meaning the gateway handles the modem part the job and the Nighthawk RAXE500 handles the router stuff. I had to go into the GatewayAdminSite and make changes to its set up. It was the only time once ever been able to get into that one. ( I’ve never been able to get into my Netgear routers site). Everything works fine I was just wondering why it says Gateway Modem is offline.
TIEfitrRAXE500
michaelkenward
Nov 07, 2023Guru - Experienced User
What is that gateway?
The term "Fiber Optic" doesn't mean much. Every Internet service has fibre optic somewhere in the network.
If you get an optical fibre to your front door, and not just to somewhere up the road, this usually comes into an optical network termination (ONT). Many ONTs don't have a router component. So without knowing what your gateway is it is hard to understand why you cannot access the graphical user interface (GUI).
Good question. Tell us more and someone may have some ideas.
First, what is it that says "Gateway Modem is offline".
Any how are you trying to get into it?
