jbuttle63
May 22, 2021Follower
Netgear app sucks
Title speaks for itself. What is up with the Netgear app? I installed it on my Iphone and I am unable to log into my Netgear router. After going through what seemed like a million steps (including se...
Bretableman
Jun 27, 2021Initiate
Ah, no… Netgear can own their user hostile and buggy interfaces and apps. What is this? 1992?
My phone app almost worked right for a few months, then the speed test died, no updates to remove the dead option, then did get an up date and crashed my whole network until after I did a factory reset. Lost 2 hours of work at home time from my pay check.
The network interface as of right now is buggy, would not allow me to turn on the guest network, etc., etc.
So, no. Don’t try to flip the script on someone trying to see if any help is available. Netgear can own it.
Shuff
Sep 22, 2021Initiate
I agree with the app being a steaming pile.
I'm currently troubleshooting an issue with the wifi not working on my router but wired is fine. So when you say "Well, you just need to connect to your wifi and use the app", I find it insulting because I cannot even do that since your product has decided to die on me a year after purchasing. To make matters worse, when I do try to access from my wired connection, it either tells me to go get the app or redirects me to a site that is a retail site to sell Netgear products! Garbage setup Netgear, if this product is dead or dying, you bet I'm going to look at other solutions.
- michaelkenwardSep 22, 2021Guru - Experienced User
Have you posted a message about that issue? I can't find any other posts from you.
This bit may need some explaining.
Shuff wrote:
...your product has decided to die on me a year after purchasing.It is misleading to tall of "your product" here. It isn't "our" product
This community is essentially a user-to-user venue with some, but not much, input from a small band of Netgear techies. (Look for the "N" symbol by the usernames.)
Most answers come from fellow users with no connection to Netgear. They just have time on their hands and a lot of collective experience. They are also familiar with the sort of problems that turn up here.
If you want "official" support then you should go through the right channels.
