jbuttle63
May 22, 2021Follower
Netgear app sucks
Title speaks for itself. What is up with the Netgear app? I installed it on my Iphone and I am unable to log into my Netgear router. After going through what seemed like a million steps (including se...
Shuff
Sep 21, 2021Initiate
I agree with the app being a steaming pile.
I'm currently troubleshooting an issue with the wifi not working on my router but wired is fine. So when you say "Well, you just need to connect to your wifi and use the app", I find it insulting because I cannot even do that since your product has decided to die on me a year after purchasing. To make matters worse, when I do try to access from my wired connection, it either tells me to go get the app or redirects me to a site that is a retail site to sell Netgear products! Garbage setup Netgear, if this product is dead or dying, you bet I'm going to look at other solutions.
michaelkenward
Sep 22, 2021Guru - Experienced User
Have you posted a message about that issue? I can't find any other posts from you.
This bit may need some explaining.
Shuff wrote:
...your product has decided to die on me a year after purchasing.
It is misleading to tall of "your product" here. It isn't "our" product
This community is essentially a user-to-user venue with some, but not much, input from a small band of Netgear techies. (Look for the "N" symbol by the usernames.)
Most answers come from fellow users with no connection to Netgear. They just have time on their hands and a lot of collective experience. They are also familiar with the sort of problems that turn up here.
If you want "official" support then you should go through the right channels.
