JJ77
Dec 14, 2019Tutor
NETGEAR APP
I can access the router on line, but the app does not take the same name and password and will not connect? The router
- Dec 15, 2019
Fixed it this morning. REBOOTED router again and app found it! Thanks again for your interest in my problem!!!
michaelkenward
Dec 15, 2019Guru - Experienced User
Can you take us through this in a bit more detail?
What do you mean by "can access the router on line"? With a wired connection and a browser? Something else?
Which app?
Remember, mobile devices have to connect to the wifi before you can begin to manage the browser.
- JJ77Dec 15, 2019Tutor
On line through browser (wireless) with laptop. The other access that is not working is the nighthawk app on my iPad. Was working previously? Had a problem with my modem that Century link walked me through a fix which required restarting modem/router. Everything else works fine, but NETGEAR app could not connect with my name/password. I uninstalled and reinstalled app, but still says name password not valid? Thank you for your reply
- michaelkenwardDec 15, 2019Guru - Experienced User
There are several passwords you could use. The one that connects to the wifi, the one that gets into the router's controls and the pair for MyNetgear that allow you to use remote control.
- JJ77Dec 18, 2019Tutor
JJ77 wrote:Fixed it this morning. REBOOTED router again and app found it! Thanks again for your interest in my problem!!!
Turns out the problem is not resolved! Once the router is reset the Nighthawk app works that one time. Then after that you have to keep restarting the router to make the nighthawk app
work. I can enter the user/password in my laptop browser and get into the router setup. But entering the same password/user cannot acces the RAX80 nighthawk app on my ipad nor the genie on my laptop. The genie at least shows all other items like map. other networks but not the router settings. Really at a loss.
