JJ77
Dec 14, 2019Tutor
NETGEAR APP
I can access the router on line, but the app does not take the same name and password and will not connect? The router
- Dec 15, 2019
Fixed it this morning. REBOOTED router again and app found it! Thanks again for your interest in my problem!!!
michaelkenward
Dec 18, 2019Guru - Experienced User
JJ77 wrote:
I knew I had double NAT so I contacted Centurylink previously as they originally set up the C3000Z dual DSL line input modem. They said to disable NAT on the The C3000Z, but when I did, could not access the internet. Subsequent calls had me enable the NAT and then can use internet again.
I would look beyond Centurylink for advice.
JJ77
Dec 25, 2019Tutor
Ok. getting ready to put the RAX80 in AP mode after reading your replies and web link. I did static assign my ipad and laptop IP addresses and that seemed to fix the Nighthawk and Genie app problem, but I realize there are other problems with dual NAT. Does the dual NAT have an effect on dropping devices so I have to reboot router? The reason I ask is I have that problem, but there are a lot of other forum members that seem to have the problem with the RAX80 router. If the dual NAT has nothing to do with that problem, I am thinking of getting a new router?
