jabrightmom
Sep 05, 2023Initiate
Netgear app
Netgear app device manager not working. I have uninstalled/reinstalled multiple times and received the same message every time : "Sorry, your device list failed to load. Please try again later." The...
- Sep 06, 2023
Thanks to those who responded. Because of my lack of patience 😬and not believing anyone would respond 😬, I did a hard reset on the router. After much weeping and gnashing of teeth, got all of our devices reconnected and the app is now working.
michaelkenward
Sep 06, 2023Guru - Experienced User
Have you tried getting into the RAX50 using the #browser graphical user interface (GUI)? That is always going to be a better way to manage a router. That would also rule out problems with the app. (Which one do you have? Android or iOS?)
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
- jabrightmomSep 06, 2023Initiate
- FURRYe38Sep 06, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
