shanafan
May 02, 2020Apprentice
Netgear Armor doesn't show my router
Hello, I went to check out Netgear Armor's website, and when I signed into my Netgear account, it doesn't show my XR500 router appear. It says "No routers associated with this account." So, I...
michaelkenward
May 02, 2020Guru - Experienced User
There are two places where you can look for help:
You might get better and quicker replies, and find other answers, over in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Armor has its own bolt hole:
NETGEAR Armor - NETGEAR Communities
You might do better to try there.
shanafan
May 03, 2020Apprentice
Thanks! I'll post there.
