TastyMarkers
Feb 10, 2017Follower
Netgear Genie - Network Map switching connections
On the netgear genie network the map shows switching devices on and off every mintue. For example, one of the ip is 192.168.1.5 then after a few second it changes to 192.168.1.45. It goes on forever. I believe this is making me lag in ping.
How did you configure your router full DHCP or fixed IP.
It can be a wifi restart!
- DexterJBNETGEAR Moderator
Hi TastyMarkers,
You can try doing address reservation. You may find the link below helpful.
http://kb.netgear.com/app/answers/detail/a_id/24091
Dexter
Community Team
Hi TastyMarkers,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
