hyperlance
Apr 24, 2016Guide
Netgear Genie 2.4.26 Huge Window Size Windows 10
I just updated to Genie 2.4.26 and now the windows for it us huge (i.e. the window is larger then my desktop). Even the menu when you right click on the icon in the bottom right corner section is lar...
hyperlance
Apr 25, 2016Guide
Thanks, however the option is not on.
I took some screen shots
And finally
DexterJB
Apr 26, 2016NETGEAR Moderator
Hi @hyperlance,
Please try checking the option "Disable display scaling on high DPI settings".
Dexter
Community Team
- hyperlanceApr 28, 2016Guide
DexterJB wrote:Hi @hyperlance,
Dexter
Community Team
Dexter,
That has not helped eiher.
