hyperlance
Apr 24, 2016Guide
Netgear Genie 2.4.26 Huge Window Size Windows 10
I just updated to Genie 2.4.26 and now the windows for it us huge (i.e. the window is larger then my desktop). Even the menu when you right click on the icon in the bottom right corner section is lar...
baycen
May 04, 2016Aspirant
Having same issue. Have tried both solutions below, as well as utilizing the "Troubleshoot Compatability" Win10 function. Have Uninstalled- reinstalled several times. Have there been any updates to this issue?
- DexterJBMay 04, 2016NETGEAR Moderator
Hi all,
Let me check on this. I will post an update once available.
Dexter
Community Team
- madazMay 05, 2016Aspirant
I cant belive more people havent complained or someone actually (from netgear) tested the software on windows 10 and seen what it does
- TrelMay 08, 2016Aspirant
I am running Windows 8.1 and was having the same issue. I went to C:\Program Files (x86)\NETGEAR Genie\bin and opened the Compatibility settings for NETGEARGenie.exe and told it to run in Compatibility Mode for Windows 7. That seems to have resolved the issue.
- hyperlanceMay 09, 2016Guide
Trel wrote:I am running Windows 8.1 and was having the same issue. I went to C:\Program Files (x86)\NETGEAR Genie\bin and opened the Compatibility settings for NETGEARGenie.exe and told it to run in Compatibility Mode for Windows 7. That seems to have resolved the issue.
Thanks Trel. Gave that a go, still not working.
