hyperlance
Apr 24, 2016Guide
Netgear Genie 2.4.26 Huge Window Size Windows 10
I just updated to Genie 2.4.26 and now the windows for it us huge (i.e. the window is larger then my desktop). Even the menu when you right click on the icon in the bottom right corner section is lar...
Trel
May 08, 2016Aspirant
I am running Windows 8.1 and was having the same issue. I went to C:\Program Files (x86)\NETGEAR Genie\bin and opened the Compatibility settings for NETGEARGenie.exe and told it to run in Compatibility Mode for Windows 7. That seems to have resolved the issue.
madaz
May 10, 2016Aspirant
Trel wrote:I am running Windows 8.1 and was having the same issue. I went to C:\Program Files (x86)\NETGEAR Genie\bin and opened the Compatibility settings for NETGEARGenie.exe and told it to run in Compatibility Mode for Windows 7. That seems to have resolved the issue.
Also doesnt work for me, I have found an older download and reverting back to
NetGear Genie 2.4.15.7
/edit which didnt fix what was broken
