hyperlance
Apr 24, 2016Guide
Netgear Genie 2.4.26 Huge Window Size Windows 10
I just updated to Genie 2.4.26 and now the windows for it us huge (i.e. the window is larger then my desktop). Even the menu when you right click on the icon in the bottom right corner section is lar...
intelemetry
Sep 30, 2016Initiate
Seems like I've found a workaround (not a proper solution). I hope this helps the devs at Netgear/Genie.
Out of my three computers, this problem never affected the ones that had 1920X1080 resolution -- I had this problem only with the desktop that had a 2560X1080 monitor (All my PCs are Windows 10). So that gave me the initial clue.
Here's my workaround:
1. Exited Netgear Genie (by rightclicking the tray icon and choosing exit)
2. Went to my "C:\Users\%USERNAME%\Appdata\Local\NETGEARGenie\" folder
2. Opened the config.ini file in this folder with Notepad
3. Changed the third line so that it reads:
screen_resolution=1920*1080
4. Saved and closed the file.
5. Right-clicked the config.ini file, opened the properties and made it read-only
6. Opened Genie and it's looking normal!
I'm calling it workaround because of Step #5. I've found that if I don't make it read-only that the resolution changed back to 2560*1080 (which actually IS the resolution of my monitor) and the huge windows problem returned.
As usual, please do this at your responsbility and I am not liable if anything gets broken.
The main problem is I guess the app wasn't designed properly to work in Ultrawide (21:9) or high resolutions -- I hope this gets corrected soon.
Hope this helps.
