teknopzent
Jan 24, 2017Aspirant
Netgear Genie 2.4.26 Tiny Window Size Windows 10
I have a new windows 10 computer with a 13" screen and the genie window is so tiny I have great difficulty reading or working in it. I have tried the windows 7 compatability and the "Disable display ...
- Jan 25, 2017
teknopzent wrote:
I have my resolution set to 2560 x 1440. It was the factory setting. This app is the only one that is smaller than usual. It is fine on my other window 10 computer and my window 7 computer.
Does it resolve if you set the resolution lower (1280x720)?
William10a
Jan 24, 2017Master
Have you updated your Genie software?
teknopzent
Hi William
I just downloaded the app/software from Netgear so it should be the latest. The software/Firmware for the wireless is current according to the Netgear website. I'm running windows 10 (unfortunately) on two other computers here and the window size is normal.
Thanks Bob
- William10aJan 24, 2017Master
Windows 10 may be the latest os out for windows but it's greatest windows xp takes the award for that in fact some companies still have windows xp to run their software from 10 or more years ago and a server long forgetten about still carrying some task in a netgear like a print server.
- teknopzentJan 24, 2017Aspirant
Yes XP was good too. Liked 7 the best. Any thoughts on why this windows 10 has the small window for genie? Bit of a problem when I cannot read the tabs in the window.
Bob
- StephenBJan 24, 2017Guru - Experienced User
What is the screen resolution? You might need to set the display DPI.
Are other applications also too small to read?
