teknopzent
Jan 24, 2017Aspirant
Netgear Genie 2.4.26 Tiny Window Size Windows 10
I have a new windows 10 computer with a 13" screen and the genie window is so tiny I have great difficulty reading or working in it. I have tried the windows 7 compatability and the "Disable display ...
- Jan 25, 2017
teknopzent wrote:
I have my resolution set to 2560 x 1440. It was the factory setting. This app is the only one that is smaller than usual. It is fine on my other window 10 computer and my window 7 computer.
Does it resolve if you set the resolution lower (1280x720)?
teknopzent
Jan 25, 2017Aspirant
Hi Stephen
Thanks
Bob
William10a
Jan 25, 2017Master
It has the do with way windows 7 and windows 10 video drivers works they changed the way windows reads the size command may be the problem will be fixed in the issue of the genie program.
