teknopzent
Jan 24, 2017Aspirant
Netgear Genie 2.4.26 Tiny Window Size Windows 10
I have a new windows 10 computer with a 13" screen and the genie window is so tiny I have great difficulty reading or working in it. I have tried the windows 7 compatability and the "Disable display ...
- Jan 25, 2017
teknopzent wrote:
I have my resolution set to 2560 x 1440. It was the factory setting. This app is the only one that is smaller than usual. It is fine on my other window 10 computer and my window 7 computer.
Does it resolve if you set the resolution lower (1280x720)?
teknopzent
Hi Stephen
Thanks
Bob
Jan 25, 2017Guru - Experienced User
- teknopzentJan 25, 2017Aspirant
Hi Stephen
Well, that was interesting. I tried reseting ( as you suggested) my resolution to 1280 x 720 and that blew the window up bigger than my screen. So I started working my way back up the scale. I'm now back to 2560 x 1440 ( my highest setting and where this all started) and all seems to be working as advertized. Go figure.
Once again, Thank you; this seems to have solved my problem.
Bob J
