SBYMOM
Oct 09, 2016Tutor
Netgear Genie and Android app - bypass login does not work
O.K. All was well till I purchased a new android phone Samsung Galaxy J7. I was always able to adjust access to filtering directly from my desktop. Now, I had to install an app on my android, so I...
SBYMOM
Oct 10, 2016Tutor
In addition, I have noticed that all of my devices are now listed in bypass login filter. This does not make sense. What happened to all of my parental controls? And, why I cannot put my android in the bypass login filter when everything else is there already? I am really not sure what is going on with the parental controls.
Blkjak
Oct 12, 2016Tutor
Same issue on my IOS apps, ever since upgrading the new Genie App. Frustrating!!
- DexterJBOct 18, 2016NETGEAR Moderator
1. What is the firmware version of your devices?
2. What version of NETGEAR Genie do you have installed?
3. Have you tried uninstalling and reinstalling the app then rebooting the router?
Dexter
Community Team
