SBYMOM
Oct 09, 2016Tutor
Netgear Genie and Android app - bypass login does not work
O.K. All was well till I purchased a new android phone Samsung Galaxy J7. I was always able to adjust access to filtering directly from my desktop. Now, I had to install an app on my android, so I...
Frogz
Nov 23, 2016Aspirant
Frogz
- screenshot of error... keep checking for progress on this problem, any solution?
- DexterJBNov 24, 2016NETGEAR Moderator
Hi Frogz,
1. What Android version is the phone using?
2. Have you tried using another Android device? If yes, does the issue persist?
3. What is the model of the phone/s that are experiencing the issue?
4. Was it working before?
5. Does it apply to all bypass logins if you have multiple?
Dexter
Community Team
- FrogzNov 29, 2016Aspirant
Nugat 7.1.1
I have not. Last time it worked was on Motorola Nexus 6
LG Nexus 5x
Nexus 6 it worked, couldn't tell you how long ago
I am the only one that has a bypass profile in my household/account.
