sweathogsparky
Sep 12, 2015Aspirant
Netgear Genie android app cannot login
When I try logging into my R7000 using the Android Netgear Genie app, I get a message stating "The network connection is busy, try again later. If it fails constantlly, power cycle your NETGEAR route...
southernclipper
Oct 20, 2015Aspirant
I am having the same extact issue. I am running 9.0.2 IOS on my IPad, everything was working fine until recently updated the Genie App and now the login greyed out unless I type password in the password field. The Genie App is 2.4.18. I thought it may have been because I was running an older version of Netgear F/W on my R7000. I was running V1.0.30.80 - so I upgraded to V1.0.4.28. Factory Reset Router and same freaking issue. I removed and reinstall the Genie App and same issue. I wish I could download the older version of the Genie App becasue it was working without any issues. Netgear obivously broke something in 2.4.18. Works fine from Android. Anyluck this will be fixed before 2016.
DexterJB
Oct 21, 2015NETGEAR Moderator
Hi southernclipper,
Please try downloading the latest version of the app which is version 2.4.22.
Dexter
Community Team
