love_cisco
Jun 26, 2017Tutor
Netgear Genie Android App Login Failure, need help for troubleshooting
I'm trying to login using the Genie app on my Nexus 7 (2013) tablet. When I enter the password, I get the following message. The NETGEAR router was not found or is not supported. Make sure that...
michaelkenward
Jun 26, 2017Guru - Experienced User
Is this Local access?
Did you try feeding in the IP address to the Android genie?
- love_ciscoJun 27, 2017Tutor
yes, it is local access.
I also input the router local IP address in the Android genie, but still not working.
Does Netgear router has the debug CLI like Cisco router for futher troubleshooting?
- nonamenonameJul 03, 2017Aspirant
What is the solution for this?
I installed Genie. Logged it yesterday. Conected with OpenDNS for parent control. Was working today on my Router Nighthawk X6 R7900 on firmware V1.0.1.3 (not sure about the version). Then I updated the firmware
V1.0.1.18_10.0.20
I can login from laptop, I can login via the browser of Androin phone, but not from Genie.
- michaelkenwardJul 03, 2017Guru - Experienced User
nonamenoname wrote:I can login from laptop, I can login via the browser of Androin phone, but not from Genie.
Is that the desktop genie? (The standalone utility?)
That also has the option of feeding in the IP address. I have to do that. The genie got sick some time ago.
