Scooot
Sep 09, 2017Aspirant
Netgear Genie App and BT home hub 5
Hi all, I have a BT home hub 5 and a netgear ex7300 extender. Should I be able to use the netgear genie app on my iPhone/iPad. I am unable to connect it to my router for some reason.
michaelkenward
Sep 10, 2017Guru - Experienced User
Netgear's genies won't see "third party" modem/routers. I've tried.
Scooot
Sep 10, 2017Aspirant
Many thanks. At least I know I dont have a fault. :)
- michaelkenwardSep 10, 2017Guru - Experienced User
Just using a Homehub!
Scooot wrote:
At least I know I dont have a fault. :)- ScoootSep 16, 2017Aspirant
Not now, I've just bought & setup a D7800 :)
- michaelkenwardSep 16, 2017Guru - Experienced User
Uh oh. Does that support the flavour if IPv6 that BT uses? A lot of Netgear modems do not.
That may not matter at the moment, but one day it could be important.
Re: IPV6 with BT Infinity - NETGEAR Communities
IPV6 D7000 not working properly - NETGEAR Communities
D7000 Nighthawk no IPV6 support with BT Infinity? - NETGEAR Communities
