dluhop
Sep 03, 2015Aspirant
NETGEAR Genie App: Changing Device Name & Type
I have entered the wrong network device name and type for my iPhone as it appears on the Mobile Genie network map. I can't change them while my phone is active. I don't see any edit capability. I ...
dluhop
Dexter, the desktop client shows the correct device name and type for my iPhone. On my iPhone, itself, the “modify” option does not appear when I click on the iPhone icon that is labelled incorrectly. Only those devices that have blue lines can be modified. Thanks for getting back to me so quickly. I hope you can understand what I’m talking about.
DexterJB
Sep 03, 2015NETGEAR Moderator
Hi dluhop,
I suggest uninstalling the application and reinstall it. You should be able to modify that through the iOS application itself.
Rgeards,
Dexter
Community Team
- dluhopSep 04, 2015Aspirant
That sort-of worked. I still can't edit the device name. But, it did update the type properly.
