Lsbcal
Oct 07, 2014Aspirant
Netgear Genie app does not open
I've been using this off and on for a few years. Just tried to bring up the Netgear Genie app and it did not respond. The wireless router is working fine. I have a Win 7 desktop PC as the main comput...
ralphfur
Nov 03, 2015Aspirant
Good Evening;
I am also having issues with Genie and Windows 10. I get the message that an error has occured. Reloading does NOT help. Genie seems to work just fine on Windows 7 machines and on my iPad. Just my Windows 10 laptop seems to be in trouble. Does this mean that the current version of Genie is NOT compatible with Windows 10 and that I need to roll back to the previous version of Genie?
THANKS!!!
DexterJB
Nov 04, 2015NETGEAR Moderator
Hi ralphfur,
Yes, there have been several reports that the latest version encounters an issue with Windows 10. As a work around, you can install the older version using the link below.
http://files.netgear-support.com/go/?a=d&i=Nouncx3OlX
Dexter
Community Team
- ralphfurNov 09, 2015Aspirant
THANKS for the clarification!!!!!!:smileyhappy:
Should I ask the Router Beta Team for a solution to this or will I be notified when a fixed version of Genie is out?
Again, Thanks for your response!!
Best regards,
Ralph Furlong
Tacoma, WA
- stepharnieJan 03, 2016Aspirant
This link for the prior version is asking for a code and is not accessible. I am still having this issue when I try to uninstall and reinstall and cannot get the Genie to work on my Windows 10 PC. Help!
- DexterJBJan 04, 2016NETGEAR Moderator
Hi stepharnie,
We apologize for the inconvenience this has caused you. Rest assured, we are investigating on this issue. You may use the download link below for the previous version (2.4.12) of the program.
https://drive.google.com/file/d/0Bz-pjmQaYmk6Vk92eE81a20xRjg/view?usp=sharing
Dexter
Community Team
- KeriJan 05, 2016Aspirant
That link is not working for me, please HELP
UPDATE: Sorry Dexter it did work, I guess I had to be signed in for it to work. Thank you!! :)
