Lsbcal
Oct 08, 2014Aspirant
Netgear Genie app does not open
I've been using this off and on for a few years. Just tried to bring up the Netgear Genie app and it did not respond. The wireless router is working fine. I have a Win 7 desktop PC as the main comput...
ralphfur
Nov 09, 2015Aspirant
THANKS for the clarification!!!!!!:smileyhappy:
Should I ask the Router Beta Team for a solution to this or will I be notified when a fixed version of Genie is out?
Again, Thanks for your response!!
Best regards,
Ralph Furlong
Tacoma, WA
DexterJB
Nov 10, 2015NETGEAR Moderator
Hi ralphfur,
No need. Engineering was already made aware of this. I recommend keeping an eye out for the next update for the NETGEAR Genie program.
Dexter
Community Team
- ralphfurNov 10, 2015Aspirant
Thanks!!
Later,
Ralph
Tacoma, WA
- JerryCaliforniaNov 20, 2015Aspirant
I just installed a new Netgear router and had the same problem with windows 10. Fortunately the second download site worked.
