spinninfree
Jul 12, 2016Guide
Netgear Genie App for Android - Login Remote access - No Internet connection detected.
Using a Samsung S5 - model #SM-G900T, with android version 6.0.1, security patch level is May 1, 2016 - and have had the Netgear Genie app - and have been using the Remote access feature on a daily b...
- Aug 24, 2016
I had a successful remote access this evening (not w/Beta) - with no error msg of No Internet connection detected. It appears that there has been a break through and that the app is behaving as it did prior to this error.
Hope the rest of you have the same success!
Spinninfree
Genienthebottle
Jul 14, 2016Guide
Same. Galaxy S5 - 2 Netgear routers. No Remote Access. Local access works ok
