spinninfree
Jul 12, 2016Guide
Netgear Genie App for Android - Login Remote access - No Internet connection detected.
Using a Samsung S5 - model #SM-G900T, with android version 6.0.1, security patch level is May 1, 2016 - and have had the Netgear Genie app - and have been using the Remote access feature on a daily b...
- Aug 23, 2016
I had a successful remote access this evening (not w/Beta) - with no error msg of No Internet connection detected. It appears that there has been a break through and that the app is behaving as it did prior to this error.
Hope the rest of you have the same success!
Spinninfree
Santerianumero1
Aug 11, 2016Guide
If you have an Android phone make sure to go give their app a nice review for such a poor sense of urgency to fix this. I'm going to reconsider Netgear for personal use and stop recommending them at my job.
- Roger00000Aug 11, 2016Initiate
Done (reviewed in Google Play store)
