spinninfree's avatar
Jul 12, 2016
Netgear Genie App for Android - Login Remote access - No Internet connection detected.
Using a Samsung S5 - model #SM-G900T, with android version 6.0.1, security patch level is May 1, 2016 - and have had the Netgear Genie app - and have been using the Remote access feature on a daily b...
  • spinninfree's avatar
    spinninfree
    Aug 23, 2016
    I had a successful remote access this evening (not w/Beta) - with no error msg  of No Internet connection detected.  It appears that there has been a break through and that the app is behaving as it did prior to this error.
    Hope the rest of you have the same success!
    Spinninfree
