Ricky12345's avatar
Ricky12345
Follower
Dec 16, 2016
Netgear Genie App for Android - Login Remote access
Hi, I am unable to login remotely to my Genie app (outside of router/wifi coverage). Model: AC1900 Nighthawk. The desktop App does not have an option to Login as REMOTE ACCESS. Refer screen shot. Ple...
  • DexterJB's avatar
    DexterJB
    Jan 12, 2017
    Hi @donaldlund2010,
    If you are in the process of setting up remote login via NETGEAR Genie for Android then the link below may help you out.
    http://kb.netgear.com/26846
    Make sure that the Android device is connected to your own network. You can reset the router if the password issue persists.
    Dexter
    Community Team
