wml52
Mar 06, 2017Aspirant
Netgear Genie app for android
I recently updated the genie app on my android phone, since the update I longer have the ability to measure signal strength by room. The new updated version of the genie app seems to do less then the ...
michaelkenward
Mar 07, 2017Guru - Experienced User
There is a dignal strength indicator on the "wifi" page.
wml52
Mar 07, 2017Aspirant
Thank you Michaelkenward for your response.
Yes I know, but previous to the 3.1.12 update I was able to keep a log of each room and record the signal strength. The 3.1.12 version doesn't appear to have as many features. I would prefer the old look with more features over the new look with less features.
