kglithero
Oct 30, 2016Aspirant
Netgear Genie Can't Identify Router and I can't use routerlogin.net
This has all started because I want to use the parental controls. I downloaded the Genie app on my laptop (a windows 10 pc) and ran it....it shows I am connected to the internet, but the programm...
Anonymous
Oct 31, 2016You're Not using Netgear firmware on the router so it won't work.
- kglitheroOct 31, 2016Aspirant
Thank you for the feedback searay!
So do you think I should upgrade the firmware? I'm just nervous about making the router unsuable.
Thanks again. Any advice is welcome!
- AnonymousOct 31, 2016
If you want to use NG Apps you'll need to revert to NG FW.
The "unusable" concern Is always a possibility when deciding to use 3rd party Firmware so do you homework and follow the instructions carefully if you decide to revert back to NG firmware.
