doclouie
Sep 05, 2016Aspirant
Netgear Genie can't login username password WNDR3400
So I recently did a hard restore on my router to set it back to the factory defaults and now I cannot login using the default username and password aka "admin" & "password". The screen below shows u...
doclouie
For some reason the photo did not show up properly.
- DexterJBSep 12, 2016NETGEAR Moderator
Hi doclouie,
1. What is the model number and firmware version of the router?
2. You may not have properly reset the router. Does your old router password work (if you changed it before)?
3. You can try resetting the router again. You may find the link below helpful.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
- doclouieSep 12, 2016Aspirant
Thank you so much for responding.
1. N750 Wireless Dual Band Model WNDR4300
2. No the old password or default "password" does not work.
3. I have reset this router at least 3-4 times and I have tried it on both my home desktop, home laptop and a friends desktop with the same issue.
I put in the default "admin" and "password" ant the text box flashes and the information that I put in disappears and it says the username and password are incorrect. It is at the factory default.
I am ready to throw the router in the garbage and go with a different company. Crazy as I have only bought netgear routers.
