doclouie
Sep 05, 2016Aspirant
Netgear Genie can't login username password WNDR3400
So I recently did a hard restore on my router to set it back to the factory defaults and now I cannot login using the default username and password aka "admin" & "password". The screen below shows u...
Reeny
Nov 03, 2016Aspirant
Im having the same problem i used to be sble to login to netgear genie on my iphone app with default password "password" but now it says incorrect password. Its like someone has chsnged my password on me.
- DexterJBNov 04, 2016NETGEAR Moderator
Hi Reeny,
1. What is the model number and firmware version of your device?
2. Are you still able to login the router UI via a browser using the same credentials?
3. Please try using another device with the NETGEAR Genie app/program installed.
4. Try changing your router password.
Dexter
Community Team
