sauermk97
Apr 03, 2016Follower
Netgear Genie closes Windows 10 computer
I went to Netgear's website to download the latest version of Netgear Genie, and it closes immediately after opening. I read through forum article after forum article seeing others complain of the s...
DexterJB
Apr 06, 2016NETGEAR Moderator
Hi @sauermk97,
You may try the following steps.
1. Install the latest version of NETGEAR Genie. You may use the download link below.
http://netgear.com/home/discover/apps/genie.aspx
2. Once you have successfully installed the program, navigate to C:\Program Files (x86)\NETGEAR Genie\bin
3. Delete the drivers folder.
4. Download the drivers for the previous version of NETGEAR Genie using the download link below.
https://drive.google.com/file/d/0Bz-pjmQaYmk6Z0xTX3d3SVFLZ0k/view?usp=sharing
5. Unzip the file to your preferred location (Desktop would be easy to locate). It will contain the drivers folder.
6. Copy the drivers folder that you have just unzipped and navigate back to C:\Program Files (x86)\NETGEAR Genie\bin
7. Paste the drivers folder.
8. Relaunch the NETGEAR Genie program
Dexter
Community Team
Philbarb
Apr 19, 2016Aspirant
Thanks so much for solving my problem of netgear Genie closing on my new Windows 10 PC. followed the procedure and it now works.
- DexterJBApr 19, 2016NETGEAR Moderator
Hi @Philbarb,
Good to know it worked for you. You can mark the post as the solution so that others can check it as well if they are experiencing the same issue.
Dexter
Community Team
