Whitehat76
May 22, 2016Aspirant
netgear Genie crash on surface Pro 3
Hi Everybody ! Anybody has any insight ? I can run Netgear genie on a Surface pro 1, on a laptop, on Asus Vivo pc, all either with windows 7 or windows 10. But on my Surface Pro 3, it always...
DexterJB
May 29, 2016NETGEAR Moderator
Hi Whitehat76,
1. What version of NETGEAR Genie do you have installed?
2. Has it worked before with a previous version?
3. Are you getting an error message? If yes, what is the error message?
4. Have you tried uninstalling and re-installing?
Dexter
Community Team
- Whitehat76May 30, 2016Aspirant
1) The last version of course
2) It has worked with a previous version, but I cannot be sure which one.
3) General error message (windows) : The software has stopped working........
4) Of course :)
Thank you.
- DexterJBMay 31, 2016NETGEAR Moderator
Hi Whitehat76,
Please try installing the previous version of the program while we investigate further on this. You may refer to the link below.
https://drive.google.com/file/d/0Bz-pjmQaYmk6a2hrRFBfMzkwYTg/view?usp=sharing
Dexter
Community Team
