pmhowe
Feb 28, 2017Tutor
Netgear Genie crashes randomly.
I have a Netgear Netgear WNDR3700v4. I recently updated the software. Now, the genie crashes randomly. I have an iMac runing El Capitan 10.11.6. After genie crashes, I can restart it with no problems and no apparent ill effects. I worry about the underlying cause and wonder if there are bad things happening I don't know about.
Sort By
- pmhoweTutor
Hi Dexter,
Thanks for the help. I reinstalled the Genie app and everything is working fine. I don't (yet) have genie installed on my other devices, so can't tell if the proble was cross-platform.
Thanks again
Phil
- pmhoweTutor
I spoke too soon: Genie just crashed.
Genie takes a fair length of time to launch - longer than Safari, for example. I also tend to hit the "deny" button when genie asks to accept incoming connections. Not sure either has anything to do with the problem, but thought I would mention them.
- mar63Tutor
Mine is still shutting down unexpectedly. I go to look for it only to find it shut down. No crash report.
- jonnnyAspirant
Hi, Have the same problem with network genie randomaly crashing / shutting down, even after its been removed via programs add & remove thing in win 8.1 x 64, task bar still shows the icon.
it seem to never close down correctly and since install has caused problems with ether over mains lan utility, strange
only after a reboot does it clear from task bar.
kind of hoping that was to be fixed by now.
- DexterJBNETGEAR Moderator
Hi all,
Please try using the previous version linked below.
http://files.netgear-support.com/go/?a=d&i=0dj7jLmyKy
Dexter
Community Team
- krisdude007AspirantCan we not downgrade the app? We know we can downgrade the netgear router firmware
