rvwaal
Jul 09, 2017Guide
Netgear Genie crashes
Hi, Every time I launch backup, it genie timeline crashes. Additionally, Readycloud cannot write to or download files to the external hard drive or 120gb flashdrive (NTFS formatted) plugged i...
rvwaal
Jul 10, 2017Guide
Hi,
When I open Netgear Readyshare Vault, then click on the Backup tab, I get the following message: 'Genie Timeline has stopped working'. At that point, the program closes. I've reinstalled the software several times and tried installing the older drivers. Nothing helped.
I'm running a Windows 10 tablet. No android or Mac software present.
I'd appreciate any troubleshooting tips.
Bob
DexterJB
Jul 26, 2017NETGEAR Moderator
- CarlossrOct 25, 2017TutorExactly the same behavior. Win 7. Sw and fe updated.
Thanks - myryde77Nov 13, 2017Star
Hi Dexter,
Could you send me the same message? I am having the same issue as rvwaal. Updated the readyshare vault and installed the genie now when i hit backup in readyshare vault it gives the error attached. I have uninstalled and reinstalled several times. My previous version was working but not backing everything up it was supposed to so i updated and now this.
Thanks,
Doug
- rvwaalNov 14, 2017Guide
Hi all,
I'm still looking for a solution. The latest software update helped some, but did not solve the issue. Netgear has to stop marketing features that do not work. An online search indicated that these software issues and workarounds have been around for years. Next router will not be a Netgear.
- michaelkenwardNov 14, 2017Guru - Experienced User
Your first message said: "it genie timeline crashes".
I have no idea what that means.
How are you opening "Netgear Readyshare Vault"?
Desktop (PC/Mac) Genie?
Desktop app?
Browser interface?
