DeniseZ
Jul 29, 2015Follower
Netgear Genie Crashes
I have had no problem accessing the router through the browser. However, I wanted parental controls so downloaded the Netgear Genie app to my laptop. Each time I open it, it stops working almost im...
dmowbray
Oct 08, 2015Aspirant
Genie has been working fine on my Lenovo Carbon XI even after I upgraded to Windows 10 from 7. Today (9 Oct 2015) Genie informed me that an update was available -- it even said the update added Windows 10 compatibility. Well guess what. Now the program crashes on start every time. I get the message "Genie has stopped working, Windows is looking for a solution". Anyone know if there is a way to roll back to the previous, NOT IMPROVED FOR WINDOWS 10 verision, so I can run it on Windows 10?
Cheers
David
- DexterJBOct 08, 2015NETGEAR Moderator
Hi dmowbray,
We are already aware of this issue and we are working on a fix. In the mean time, you can refer to the download link below for the previous version (2.4.12) of NETGEAR Genie.
http://files.netgear-support.com/go/?a=d&i=pQOlhX1L3F
Dexter
Community Team
- dmowbrayOct 08, 2015Aspirant
Thanks for this information. I have installed the older version and it is working again.
David
- acron1Oct 24, 2015Aspirant
The link doesn't work(file not found) and Genie continues to carsch upon start....
- DexterJBOct 26, 2015NETGEAR Moderator
Hi acron1,
You may use this new download link since the previous one expired.
http://files.netgear-support.com/go/?a=d&i=4KoWqtKssb
Dexter
Community Team
- TPEvansDec 16, 2015Aspirant
Your link no longer provides access to the file of the older version of Genie. I just bought my first Netgear router excited about the better performance and have had nothing but problems! I installed Genie 2.4.18 and it crashes as soon as I open it. This is a new computer running Windows 10 and a new router I just purchased AC1900 Model R7000. Please help.
- DexterJBDec 19, 2015NETGEAR Moderator
I have sent you a message. Please check your inbox. You may use the download link below for the previous version on the program.
http://files.netgear-support.com/go/?a=d&i=Mg2J4qMu9o
Dexter
Community Team
