wolverinefan
Jan 15, 2017Aspirant
Netgear Genie for AC5300 keeps stating no internet
For about the last three weeks, I have had issues connecting the Internet with my laptops and desktop computers. The genie symbol turns red and states that there is no Internet and prompts me to fix it. For the most part, I am able to reconnect when this happens. Sometimes it will prompt to reboot the router and there are other times in the process that it will state that the there is no Ethernet cable connected. The red symbol pops up at least 4-5 times daily. Strangely, I have had no issues connecting to my Roku devices and I have never had a disruption in service to them and frankly, I am at a loss.
Here is what I have tried (multiple times) when this occurs:
- Unplug the router and modem
- Plug the modem back in and allow it to fully restart
- Once the modem has restarted I plug the router back in and allow it to fully reboot
This has provided no long term solution. I have also attempted to connect directly into the modem using an Ethernet cable, but that hasn't worked either. I have also called my cable company and them resend the signal to my modem and they have not detected any issues on their end.
Again, I have never had connectivity issues with any of my Roku devices and I am really at a loss here. This experience has been very frustrating to say the least. Anyone have any idea what I can do to fix this????
Hi nanannrose,
1. Please make sure that the laptop is connected to the correct wireless network.
2. Is the laptop getting a valid IP address from the router?
Dexter
Community Team
Sort By
- ElaineMNETGEAR Employee Retired
Welcome to the community, wolverinefan
What's the NETGEAR Genie version installed on your computer?
Did you try uninstalling/reinstalling the Genie?
What's the Operating System of your computer?
- wolverinefanAspirant
I am running Firmware Version V1.0.2.86, Operating System is OS X El Capitan V 10.11.6. I have not tried to uninstall and reinstall Genie, but I will try that later today when I have time.
- DexterJBNETGEAR Moderator
Hi wolverinefan,
Please keep us posted if that made a difference. Also:
1. You mentioned that connecting straight to the modem did not work, does that mean that you didn't have Internet connection when you bypassed the router?
2. Are all your laptops and desktops connected via wireless or wired to the router? If wireless, on which band (2.4GHz or 5GHz)?
3. Please try changing the Ethernet cable connecting the modem to the router.
4. What is the firmware version of the router?
5. Have you tried resetting the router?
6. How are the Roku devices connected to the network (wired or wireless)? If wireless, on which band (2.4GHz or 5GHz)?
Dexter
Community Team
- nanannroseAspirantIm having this same issue with myN750. I can get internet on my phone, but not my laptop.
Hi nanannrose,
Dexter
Community Team
Hi nanannrose,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
