JohnnyFRX
Feb 24, 2017Apprentice
Netgear Genie for Android - Latest version no longer reporting bandwidth statistics
Up until this new verson of Genie, I have been able to view bandwidth statistics per device/application via the network map, router, statistics. Router: R7500v2 Firmware Version: V1.0.3.4 genie Ve...
DexterJB
Mar 05, 2017NETGEAR Moderator
Hi JohnnyFRX,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- schumakuMar 05, 2017Guru - Experienced User
DexterJB ... another user, similar issue https://community.netgear.com/t5/Genie/Bug-genie-3-1-12-android-traffic-meter-not-displaying-data/m-p/1241335/highlight/false#M4897
- JohnnyFRXMar 06, 2017Apprentice
Good Morning,
It looks like the update to Genie 4.0 has corrected the issue. Thank you for the follow-up!!
Thanx,
JohnnyFRX
- schumakuMar 06, 2017Guru - Experienced User
Source? Noting like a 4.0 in Play Store. Suspect you mixed the App version (here: 3.1.12 around since around end of February, same as in the subject) with the [much to high] 4.0 Stars...
Well possible, there are dependencies with the router model and currently installed firmware - please provide details.
