JohnnyFRX
Feb 24, 2017Apprentice
Netgear Genie for Android - Latest version no longer reporting bandwidth statistics
Up until this new verson of Genie, I have been able to view bandwidth statistics per device/application via the network map, router, statistics. Router: R7500v2 Firmware Version: V1.0.3.4 genie Ve...
DexterJB
Mar 05, 2017NETGEAR Moderator
Hi JohnnyFRX,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
JohnnyFRX
Mar 06, 2017Apprentice
Good Morning,
It looks like the update to Genie 4.0 has corrected the issue. Thank you for the follow-up!!
Thanx,
JohnnyFRX
- schumakuMar 06, 2017Guru - Experienced User
Source? Noting like a 4.0 in Play Store. Suspect you mixed the App version (here: 3.1.12 around since around end of February, same as in the subject) with the [much to high] 4.0 Stars...
Well possible, there are dependencies with the router model and currently installed firmware - please provide details.
