SnuggleBuddy
Oct 22, 2017Tutor
Netgear Genie for Mac Installer can not be opened
I am running Mac OS 10.11.6. I'm running Netgear Genie version Version 2.4.22 for Mac OS. There is an Genie update available, 2.4.26, though when I download it, it won't install and I get a pop up sta...
- Retired_MemberOct 26, 2017
I have the same problem. The downloaded install image for Genie version 2.4.26 is formatted in APFS format. It won't install on any older version of Mac OS than High Sierra, so the update description saying that 'minimum Mac OS version is 10.7.5' is wrong.
SnuggleBuddy
Oct 22, 2017Tutor
Here is a screen grab of the dialog box. screen grab
scarface4U
Oct 23, 2017Aspirant
I have the same problem, I'm running OS 10.7.5, do you got any answers? Thanks
- SnuggleBuddyOct 24, 2017Tutor
Do you get the same dialogue box?
- scarface4UOct 25, 2017Aspirant
YES!
