SnuggleBuddy
Oct 22, 2017Tutor
Netgear Genie for Mac Installer can not be opened
I am running Mac OS 10.11.6. I'm running Netgear Genie version Version 2.4.22 for Mac OS. There is an Genie update available, 2.4.26, though when I download it, it won't install and I get a pop up sta...
- AnonymousOct 26, 2017
I have the same problem. The downloaded install image for Genie version 2.4.26 is formatted in APFS format. It won't install on any older version of Mac OS than High Sierra, so the update description saying that 'minimum Mac OS version is 10.7.5' is wrong.
Anonymous
Oct 26, 2017I have the same problem. The downloaded install image for Genie version 2.4.26 is formatted in APFS format. It won't install on any older version of Mac OS than High Sierra, so the update description saying that 'minimum Mac OS version is 10.7.5' is wrong.
- ScubaRoOct 29, 2017Aspirant
Just keeping the discussion alive as I have the same issue.
Any solutions Netgear ??
- SnuggleBuddyNov 01, 2017Tutor
Thanks Abubasim,
That makes sense then. That explains why when the .dmg disk image tries to open there is no mountable file system to be found.
Thanks,
Snugglebuddy
- scarface4UNov 01, 2017Aspirant
Thanks:smileyhappy:
- kdruffelNov 02, 2017Aspirant
Hoping Netgear will see these posts and fix the file!!
- AnonymousNov 03, 2017
I doubt technical NETGEAR staff are visiting these forums. They most likely have a contractor company doing the moderation. It's popular with companies creating these types of forums where the users help each other, giving the illusion that you receive direct technical support from the company without paying for it.
