SnuggleBuddy
Oct 22, 2017Tutor
Netgear Genie for Mac Installer can not be opened
I am running Mac OS 10.11.6. I'm running Netgear Genie version Version 2.4.22 for Mac OS. There is an Genie update available, 2.4.26, though when I download it, it won't install and I get a pop up sta...
- AnonymousOct 26, 2017
I have the same problem. The downloaded install image for Genie version 2.4.26 is formatted in APFS format. It won't install on any older version of Mac OS than High Sierra, so the update description saying that 'minimum Mac OS version is 10.7.5' is wrong.
Anonymous
Oct 26, 2017I have the same problem. The downloaded install image for Genie version 2.4.26 is formatted in APFS format. It won't install on any older version of Mac OS than High Sierra, so the update description saying that 'minimum Mac OS version is 10.7.5' is wrong.
SnuggleBuddy
Nov 01, 2017Tutor
Thanks Abubasim,
That makes sense then. That explains why when the .dmg disk image tries to open there is no mountable file system to be found.
Thanks,
Snugglebuddy
