SnuggleBuddy
Oct 22, 2017Tutor
Netgear Genie for Mac Installer can not be opened
I am running Mac OS 10.11.6. I'm running Netgear Genie version Version 2.4.22 for Mac OS. There is an Genie update available, 2.4.26, though when I download it, it won't install and I get a pop up sta...
- Retired_MemberOct 26, 2017
I have the same problem. The downloaded install image for Genie version 2.4.26 is formatted in APFS format. It won't install on any older version of Mac OS than High Sierra, so the update description saying that 'minimum Mac OS version is 10.7.5' is wrong.
RichnSpirit777
Nov 07, 2017Aspirant
Genie will not install on my Mac..I am having an issue as well this download will not install on my Mac vers 10.11
DexterJB
Nov 08, 2017NETGEAR Moderator
Hi all,
Please try installing the previous version of Genie linked below.
http://files.netgear-support.com/go/?a=d&i=AvJtLi1CBA
Dexter
Community Team
- Retired_MemberNov 08, 2017
Thanks Dexter. That is the version I already have installed: 2.4.22. This is the version that keeps crashing. The app offers the upgrade to 2.4.26 and this cannot be installed as the downloaded DMG file was prepared on a Mac running High Sierra, resulting in it being APFS format, which cannot be opened on any older version of Mac OS. This is in spite of your upgrade description saying 'Recommended minimum Mac OS version is 10.7.5.' In reality, due to the APFS package format, the minimum Mac OS required is 10.13.
