ChipMcK
Nov 15, 2015Follower
NetGear Genie for Mac latest version
Trying to downlad latest version of Genie for Mac. not interested in the iPhone version not interested in iPad version I am seeking the version for OS X. the site http://www.netgear.c...
DexterJB
Nov 16, 2015NETGEAR Moderator
Hi ChipMcK,
This is most likely an issue with the page redirecting to another link. I will have this reported to the devs so that it can be corrected. Alternatively, you may download it from the product page of your device or you may use the download link below.
Product page option:
1. Open http://downloadcenter.netgear.com/
2. Type the model number of your device (i.e. R7000) then select the device on the drop down.
3. Under the list of Firmware/Software, select the option "More results..."
4. Select NETGEAR Genie App (Mac)
Download link option:
http://files.netgear-support.com/go/?a=d&i=MnVea8xitH
Dexter
Community Team
ChipMcK3
Nov 16, 2015Aspirant
Thank you for info.
Search on internet yeilded as Releases: 2.4.15, 2.5.1.1
But the downloads from sites always gave 2.4.10 level product
