giants14
Dec 05, 2014Novice
Netgear genie high cpu usage.
Not sure where to post this but do I need the netgear genie, because it keeps making my cpu go crazy. Thanks.
shadowsports
Dec 05, 2014Hero
Welcome to the forums. I wouldn't bother with GENIE. General consensus here is it's pretty useless. Save yourself the headache and uninstall. You can use the routers GUI to make any configuration changes you might need.
