giants14
Dec 05, 2014Novice
Netgear genie high cpu usage.
Not sure where to post this but do I need the netgear genie, because it keeps making my cpu go crazy. Thanks.
stenopete
Dec 05, 2014Tutor
You do and you don't. Depends what your needs are. Its good to have as it does make thing easier.
If you're one of those people that does everything through the browser then you don't need genie.
Side note - genie shouldn't be using a lot of CPU resources. Check for maleware and viruses. Use a good av scanner.
S..
S..
